iPhone 3GS will not start / reboot help
badger1badger
Jul 15, 2011
19
Leeds UK
Hi Guys
My phone will not boot up or start -
I have tried holding the power and home buttons and I get a silver Apple logo - it then goes black again.
When connecting to mains or pc - the same Apple logo shows then disappears
Not sure what to do now ?
Paul
iphonewarrior
13,847
699
Does iTunes recognize the device? You may have to put you phone into DFU mode and restore through iTunes.
badger1badger
Jul 15, 2011
19
Leeds UK
Hi
What is DFU mean
Not tried it on iTunes yet ?- If I 'restore' does that mean I lose all data - contacts music pictures ?
I really am a novice on iPhones
Paul
iphonewarrior
13,847
699
Hi
What is DFU mean
Paul
DFU Mode is a state in which the phone enters so it can be restored under software fault conditions.
I suggest you connect your phone to iTunes and see if you can restore. If you do restore it will wipe your phone, however if you have recently backed up your phone the loss of data will be minimal.
badger1badger
Jul 15, 2011
19
Leeds UK
Going to try iTunes today - for info thou - pressing the on / off and home together does not reset the phone - is there anything else at this stage I am missing ?
badger1badger
Jul 15, 2011
19
Leeds UK
Hi
On pressing the power and home buttons - I get the silver Apple logo - and nothing else - how do I know if it is in DFU mode ?
Or is this something you see in iTunes ?
Help!:confused:
Paul
No, but iTunes will let you know you've entered DFU mode with this popup. The iPhone screen will be black rather than showing the connect to iTunes logo:
krishnamraju
Sep 28, 2011
Dude if u wanna get to your iPhone back i got a solution but it includes jailbreaking and lose of memory
if u still wanna continue i can give u a safe process
its up to u dude think abt it
RoofMonkey
Jun 21, 2010
8,921
1,983
Hi I get a black screen with a silver Apple logo - but to confirm do I have to be connected to iTunes to enter DFU mode ?
Paul
Plug phone into computer, press and hold both the home and top button together for 10 seconds, then only release the home button for another ten seconds. iTunes should say that it has found a device that needs to be restored. Welcome to DFU mode :D
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
New
i had jailbreaked my phone many times every time i m successful but this tym i installed thi e cydia files from cyder which made my phone go down the problem is solved if we go to cydia and install repo666.ultrasnow.com and problem is fixed dats it roof monkey​
You need to star your own thread on this in our iPhone Jailbreak forum. I've moved it there for you.
Cuppa_Ace
Dec 14, 2007
OK, so as of today I'm suffering the same issue. Constant reboot at the Apple logo.
When I get home I'll connect to iTunes and follow the steps listed above.
My big questions for you guys is...
1. Will it update the the latest firmware?
2. If so, is that firmware jailbreakable? (I haven't updated in a couple years)
3. I actively use Iblacklist from Cydia... if I wipe, will it also lose all my contacts in iblacklist? or does iTunes back that up somehow?
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
Duplicate posts deleted.
