iPhone 4 Bluetooth problem with 2009 BMW
bmargolis
Jun 30, 2007
59
Picked up my iPhone 4 today and immediately paired it with my 2009 BMW with iDrive. The connection to the car drops avery few minutes. Sometimes it comes back by itself and other times I need to turn BT off and back on again. Then it will drop again. I had -0- problems with my iPhone 3G or 3GS.
Anyone else seeing a similar problem?
Bob
Jun 25, 2010
Hi,
This is not just the iPhone 4 -- it is happening now on my 3GS since the update to the 4.0 software version.
Until I updated to the newest software version, I had NO problem with Bluetooth sync with my 2010 Ford Flex --- However, it drops off and reconnects several times a day now
Cynthia
bmargolis
Jun 30, 2007
59
After much trouble yesterday, the connection has been rock solid today. Not sure what was going on but it seems to have repaired itself.
SikPup
Jun 26, 2009
146
Hopewell Junction, NY
i am having an issue connecting my iPhone 4 to my 08 dodge charger with UConnect. it times out trying to pair. i can however connect to my plantronics earpiece so I know the bluetooth works.
hw76gw98
Jul 6, 2010
You need the 2011 BMW... that's what Steve Jobs said today... it's not the phone, it's your car.. :eek:k:eek:k
I have a 2011 328xi and just upgraded my 3G to the OS 4.0 over the July 4th Weekend. Haven't tried the Bluetooth Phone connection yet, but my music no longer comes up through the iDrive system. The device shows up in the USB slot, but when I go into the device, it's like it's not there. And when I back out the iDrive menu to look at the device selection screen, my iPhone is gone!
I really hope I can downgrade the phone back... maybe do a "Factory Restore" of the device and leave it with the old old old firmware. At least it worked!
plasmo
Jul 8, 2007
123
So far Bluetooth, and also displaying songs on iDrive using my iPhone4 on my 2010 328xi has worked without any problems.
hw76gw98
Jul 6, 2010
Tried again... better, but not right.
I tried again on my lunch. This time I established the Bluetooth link before plugging in the device. That shouldn't matter, right? Since the bluetooth is only the phone connectivity and the cable/adapter is for the music. But, I plugged in the device and went for a drive. Literally, a few minutes in, the music just kicked in. I watched on the trip home and saw it connect / disconnect / connect / disconnect / then connect and play music. I didn't touch anything.
Something is wrong. I'm going to try to re-sync my iPhone tonight. If not, I guess I'll have to "load" the music into the car through the USB connection in the Glove Box. That would save me having to plug in the phone every day anyway.
plasmo
Jul 8, 2007
123
Maybe it's a loose connection with your cable.
When it works, at least the cable can double as a car-charging cable which I noticed comes in handy when you need more juice.
greeby
Apr 25, 2010
Weirdness going on with my 3GS in iOS4 as well. Was rock solid on iOS3.X but since the upgrade I can't receive calls.
I can place calls with no problem but if I get an incoming call the phone rings then disconnects from the car.
Subaru Outback 2010.
PatM
Jul 6, 2010
24
Seattle, Washington
I have 2 2009 Mini Cooper S's and the iPhone 4 paired and works perfectly so far. I guess I can't buy the new 4 wheel drive 4 door next year the iPhone may not work. LOL
I think they call it the Countryman.
Regards,
Pat
z28black98
239
Tulsa, OK
Hey OP and others with BMW's....have you guys tried www.e90post.com ? its a forum for current 3series owners and has a WEALTH of information. Do a quick search and see if anyone else is having the problem, if not post a new topic. I promise you somewhere out that on that website can help you out!. Good luck.
kcn
Jul 22, 2010
I have a 2009 X5 & got my iPhone4 2 weeks ago. I have had no problems with iDrive to sync with iPhone4. I haven't had any missed calls or anything. IN fact I haven't dropped any calls either with regards to the antenna issues. Hope it will stay that way.
kcn
Jul 22, 2010
Does anyone know if iPhone4 charges via the BMW ipod sync cable which is inside the center console ? It charges the ipods & not iPhones. Any of them, 3G, 3GS. This is because Apple changed the amp input to iPhones. It apparently much lower than ipods. So the cables wont charge.
I was hoping that this was fixed on iPhone 4 or if BMW came up with a cable that charges with 5amps. Any thoughts anyone ?
