iPhone 4 cannot connect to iTunes Store
RACERZL1
Sep 15, 2010
Phone wont let me update my apps or access iTunes. It also says I have incorrect password. I have changed the password numerous times. Its driving me crazy.
Its a stock ATT iPhone 4.
Apple iAddicted
Feb 20, 2012
269
27
If my 4s drops to edge it won't connect to iTunes, the password.... Are your cap locks on and are you putting the capitol letters correct? I get that one wrong a lot not many sites make you have atleast 1 capitol letter and 1 lower case.
You can sometimes do a reset and get your 3G signal back too.
Sent from my 32GB iPhone 4s on iOS 5.1!
Only thing iPhone is missing is an expandable memory port! Come on Apple give us a microSD port already!
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
Reboot your device by holding done the Sleep/Wake and the Home buttons down at the same time–keep holding them both down until you see the Apple logo. Ignore the "Slide to power off..." prompt and ignore the black (blank) screen.
Sent from my iPad 3
RACERZL1
Sep 15, 2010
I tried that, then went to try to update my apps, entered password,and it shows"cannot connect to iTunes store". I do have a good wifi signal. Any other suggestions?
RoofMonkey
Jun 21, 2010
8,931
1,983
Try settings, store. Click on your AppleID and select sign out. Give it a few moments, then go back and sign in. See if that does anything.
RACERZL1
Sep 15, 2010
This thing is strange. I did what you said, signed out, then back in.That went through fine. I even downloaded a free app to test it.
But, when I finished that I tried to update my apps , it asked me to sign in again, I did, then is shows cannot connect to iTunes store.
RoofMonkey
Jun 21, 2010
8,931
1,983
How can I just empty all my apps and start over.?
A few other things to try:
Settings, general, reset. Reset network settings.
Have you tried doing this on the computer through iTunes?
Syncing the device and see if iTunes will download the updates.
RACERZL1
Sep 15, 2010
Yes, I have tried both of those , no luck yet. I believe it wont sync the appa because this is a new computer.
RoofMonkey
Jun 21, 2010
8,931
1,983
General, reset, Erase all content and settings. THIS WILL TAKE YOUR DEVICE BACK TO LIKE IT WAS OUT OF THE BOX!
All caps so you'd realize this is a last ditch effort. All data will be lost, but if you want to start all over, this is a way.
RACERZL1
Sep 15, 2010
I solved it by individually deleting all my purchased apps, and then reinstalling them.
That way , I did not lose all my contacts info.
Thanks for your help.
