iPhone 4 Screen Shield
DZSlasher
Jun 8, 2009
80
I have had my iPhone 4 since it came out and have had the invisible shield full body kits on my iPhones since the 3G. Unfortunately, I have had issues with the them on my iPhone 4. I keep my iPhone in my pocket. As a result, dust gets under the screen shield and it peels off. I have installed the invisible shield many times and I made sure that I did not use it for at least 24hrs to ensure that it cured.
I was wondering if there is a better screen shield that I should get that won't keep peeling off. I only have the full body kit installed without a case. Is there another full body solution that would work better that would not require a case?
