iPhone 4s - a replacement for Incipio Edge
koby
Oct 22, 2012
Hello,
I've been using the Incipio Edge on my iPhone 4s for half a year. It served me well and took a few falls without damage to the phone.
The last time it happened, the Edge broke apart.
I'm searching for a replacement, which I want it to be with the same physical strength as the Edge, but lighter and thinner if possible.
After searching the web, I came to consider between CapsuleRebelX and Switcheasy Vulcan.
What do you think about those options? Any other recommendations for cases that will provide a decent protection against occasional falls and won't make a tank out of my phone?
Thanks,
Koby.
Tbry
Aug 27, 2012
19
hi.Switcheasy Vulcan is good. I have used it for a while. But then i changed to stand leather case from jison case.
S
SmackTom
Guest
Hello,
The SwitchEasy Avant garde hard case is also a great option. It also has a cool design on the back.
