iPhone 4S Back Panel
jo12jt1
Apr 3, 2010
69
ive had the iPhone 4s for about 4 m onths now and have just noticed that if i tap the back of the phone at a cetain plae it sounds loose. not the whole back is loose just a small section. it seems to be just in from the corner. is this something to worry about or is this normal?
sorbet
Dec 11, 2011
78
14
Ohio
Hm, hard to say. I just tapped the back of my phone all over and it sounds fine, but I don't really know what I'm listening for. If you're concerned, take it to an Apple store.
jo12jt1
Apr 3, 2010
69
it sounds like a hollow tap, like when you have not secured the glass corectly
thanks iPhonewarrior
Dano4715
Jan 19, 2012
9
I had a 3gs do the same thing I think you are describing but on the front screen (duh). I took it to Apple and they replaced the whole phone! The screen was lifting up and dust was getting underneath. Mine was making a popping noise.
