iPhone 4S Battery drainage during standby
My iPhone 4S is being used during standby... and killing the battery!
  • I have no idea
    Votes: 0 0.0%
  • Try hard reset?
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
perky_pat_x
Jul 28, 2010
68
Amsterdam
Dear friends,
I have a brand new iPhone 4S. Love it! But... whenever I leave the iPhone on standby the battery drains like crazy. Like this night. Did a full charge (from o% to 100%) and took it of the charger. When I woke up the battery was at 68%! I didn't even touch the iPhone. When I looked under the setting and 'usage' I noticed that the iPhone was 'used' (3:23) during the time I was sleeping... really? No way!
I had already (before this situation) turned off many of the notifications and location services... not push on mail (fetch) etc. Basically all the tips I know on how to preserve battery I have applied to this iPhone 4S.
Any thoughts? What can be running in the background that the phone is in 'use' while I am sleeping...
I even turned off the iCloud backup and wifi sync...
Hope you guys can help. I am abroad and working on locations and can't charge my iPhone...
Best,
Perky Pat
chazm
May 1, 2008
729
40
This happened to my last iPhone 4. I just did a hard reset and it was cured
iBoss
Oct 15, 2011
250
53
Turning off the weather and stocks widget, and also I turned off ping on restrictions. That helped me a whole bunch. Hope it helps u!
Sent from my iPhone4(S) iCafe
Roger.Taylor
Dec 8, 2011
This morning when I took my iPhone 4s off the charger I noticed that I had the TTY icon displayed, within 1hr I had lost 20% of my battery life. To remove the TTY icon I had to do a factory setting reset. Icon was cleared & now my battery is back to normal. Not sure what caused the TTY icon to be displayed or whether the battery drain was connected. But the factory reset cured both.
Heacon
Nov 3, 2011
80
I live in a bad reception area... It seems to cause a bad drainage just being home because it constantly searches for net or better net... Atm in thailand I have it in airplane mode because I don't got thai sim.. And that drains 30% during sleep just cause it searches reception... So what area u live in?
Sent from my iPhone 4s using iCafe app
Z
zbregan
Guest
I have the same problem with my iPhone 4. Yesterday I made a 1/2hour call and the battery was down to 25%, tisk, he he. It seems that for iPhone 4S I have to charge my phone daily. Apple please help out the problem otherwise you will lose your market.
C
Cconci
Guest
mine has the same problem. I have the charge it two times every day.
