iPhone 4s is stuck on Apple logo :(
hmfc-1874
Sep 10, 2011
510
34
Anyway i can fix this with out recover, or at least recover photos and texts and music ? Cheers
Mariouk
Sep 8, 2010
239
Hard reset press both power and home for 5 seconds, instead of letting go after 5 seconds keep holding them down for an additional 10 - 15 seconds it should ask to plug into iTunes
Mariouk
Sep 8, 2010
239
If that don't work repeat the process whilst plugged into iTunes on your pc
iphonewarrior
13,847
699
A simple fix: turn the device off, then connect the USB cable to your phone whilst holding down the Home button.
hmfc-1874
Sep 10, 2011
510
34
thanks man
i fixed it by rebooting it then holding the up button, this worked !
must of been somthing from cydia ?
