iPhone 4s keeps dropping WiFi connection!
Jocktaff
Dec 26, 2011
Hi, does anyone know why my iPhone 4s keeps dropping my wifi connection? All other wifi devices are fine. Need to switch on/off to reconnect. Drops connection after a very short time (5mins).
showguy
Dec 2, 2007
769
Long Island, NY
Does this happen on all wifi networks? Has it happened sinsce day one? When you setup your phone did you restore as new or from a backup?
First try to " reset network settings".
If that does not work you may want to consider that it some rare cases there have been corrupt backups causing wifi issues. If this happens on all wifi networks and has always happened you may want to consider a trip to the Apple store.
Jocktaff
Dec 26, 2011
Thanks showguy, it's a new phone so not had a chance to try many wifi connections yet. Will take your advice if it carries on and go to Apple store.
