iPhone 4s screen bug
Dex Pt'Chang
Jan 15, 2012
37
Warburton, Victoria, Australia
I found this screen bug a while ago & so far I've never heard any chatter other than one response to the YouTube video. But it's real for sure I know this much.
It involves a single touch on a particular point on the screen & it swipes! Without any dragging. Check out my video. And before anyone makes the point, the nicotine stain on my fingie...I know is grose!
I just noticed it does it on the same spot on the right hand side, if you touch it, it swipes to the right. If your trying to do it....if you have a folder or App on the bottom row,on the left side., the 1st letter on the label, diagonally down to the left, about 2-3mm.
iphonewarrior
13,847
699
This isn't a bug, it's a feature. You can change homescreens this way instead of swiping. It works on both sides of the screen. :)
liberated
Jul 19, 2007
3,238
484
It's most certainly a bug lol, features are listed, bugs are unexpected Ted aberrant behavior not listed due to being unknown by the developer.
GAO
Aug 9, 2008
55
Oklahoma
I don't think this is a bug either. It works on both sides of the screen.
Sent from my iPad using Tapatalk HD
Bullgod
Oct 15, 2012
Isn't it easier just to give it a little swipe to change screens?
Cent from my iPhone using iCafe app
talon90
Jan 17, 2009
290
29
It appears to me to be simply an extension of the pages bar that is just above the tray icons. I personally don't think it is a bug. My phone and iPad both behave the same way when touching in this area. Only works if roughly on the same line as the small dots that indicate the menu page you are on. Further, touching this area when on the home screen causing the same behaviour as a swipe to the right bringing up the Spotlight search menu.
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
Yes, this is part of anything that has a paging metaphor. You can tap the left half of the page control to scroll to the left, and the right half to scroll to the right. Happens on the home screen, weather, stocks, and in the tab view of Safari.
isteven
Dec 13, 2012
Texas
Well IF it's a feature I would think Apple would tell us THEN maybe again it's a surprise find :) and they never wanted to tell us
Docd
Oct 16, 2011
651
62
It works anywhere on the same plane as the page dots, it is a feature. I seem to remember it being mention a long time ago when 4.0 came out same time as folders and spotlight came out.
