iPhone 4S use for music only
Apr 13, 2012
Hello, Everyone.
I recently purchased an iPhone 6S and am using it as my main phone and my main everything else.
My 4S is in immaculate condition--and I found $35 as a trade-in to be an affront. I want to use my 4S to house my music, like an iPod. How do I go about accomplishing this feat?
So far, I've removed all of the apps that I know how to remove.
All the help in the world is what I need. My knowledge isn't as vast as is needed for this task. I appreciate whatever knowledge you can send my way.
Thank you,
Leesha L. Heard
Arizona
RoofMonkey
Jun 21, 2010
8,891
2,057
Should be as simple as syncing the music you have in/on iTunes to the 4s.
28,409
5,539
You can sell it for more than $35 on Craigslist. Isn't your 6s big enough to store your music? If you decided to keep it, you just need to sync the music as stated above. You'll also want to avoid doing software updates or be prepared for what will happen since it won't have an active SIM card. You'll need to move your SIM card to the 4S activate it each time you update or restore. This will require a SIM card adapter since your 6s' SIM card is smaller than the one used in a 4S.
Apr 13, 2012
Every time I attempt to sync the music only, everything else syncs too--apps, mail, etc. How do I ensure that I sync only the music?
28,409
5,539
Go through the tabs at the top in iTunes and uncheck the boxes for syncing apps and videos. Delete the email accounts from the phone through the Settings app.
MrMike6by9
Nov 16, 2008
1,482
120
70
Maryland, USA
What about using iCloud Music? Your purchased tunes & music in your library can be streamed to that old phone via wifi.
