iPhone 4s won't connect to any PC
tigeron
Jul 10, 2008
My 4s is jailbroken 5.0.1 and it will connect to wall and charge but not to any of my 3 PC's. When I connect to PC nothing happens. and 4 cables.
Previously downloaded the Software update killer on phone. Just removed it. I have rebooted PC's and phone. I called Apple they want me to pay for advice. I don't wanna restore cause I'll loose Jailbreak.
Any info PLEASE.
Ron
SenseiPhone
Jun 9, 2011
11
SenseiPhone.com
Do you have any other USB devices charging well through the PCs? Just to make sure the USB port is working well. And make sure you plug it in directly, without using any USB hub.
Have you ever charged through the computer successfuly in the past?
whereweare
May 5, 2012
My friend had a similar problem and he ended up selling his. So if that is an option, consider it.
