iPhone 5 charging cable compatible with iPad Air?
bkford
Jul 30, 2009
151
MO
scrappermamo.blogspot.com
I was told at AT&T that the charging cables are interchangeable between the iPhone 5 and the iPad Air. When I attempt to plug in the iPhone 5 cable to the iPad Air, it doesn't want to go in, so I haven't forced it. Should it work?
Sent using iCafe app
Ron7624
Nov 11, 2011
82
14
Yes it should, and you are right by not trying to force it. First of all be sure that it is the actual cable that came with the Apple device, that it is a lightning connector, and that your ipad isn't in a case that may restrict the the jacket around the lightning connector.
If fall of that is ok, take it to the Apple genius for help. Above all continue to not force it. Mfi lightning cables ARE interchangeable between devices.
bkford
Jul 30, 2009
151
MO
Thank you. This is very helpful. I have two cables, one that came with the iPhone and one that came with the iPad Air. One is black and one is white. The white one works fine in the iPad Air without struggle. The black one is the one I had tried before sending this question. I also have a Zagg Folio for the iPad Air, so that could also be the problem when trying to use the black one. At any rate, your answer tells me everything I need to resolve my issue, and I thank you very much.
Ron7624
Nov 11, 2011
82
14
You're very welcome
Josh Yates
Jul 14, 2007
563
32
Orion, MI
DO NOT use that black cable on any iPhone or iPad! No Apple device comes with a black cable...ONLY white cables. There are third party black cables, but Apple does not make a white cable. I think the black cable you're trying to use is the charging cable that came with your Zagg Folio and that is a mini-USB cable that will not work with any Apple device. In fact, you could damage your Apple device trying to use that cable. Check the ends and compare them...there will be a difference.
