iPhone 5 gets hot and won't hold charge
FuelieNova
Aug 3, 2008
636
33
I was using my iPhone 5 that was just replaced in the last month from Apple, the iPhone started getting pretty warm and battery level dropped 50% in 15 min. Charged it with a wall charger overnight and in the morning it was only 73% and hot. Let the battery drain completely down and tried to recharge, it will not take a charge. The Apple logo comes up and goes out in a couple of seconds and then comes back up again and repeats this the entire time I am trying to charge.
Any ideas, using Apple charger and cable.
tom
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
I concur with the previous poster. This could be an unsafe iPhone, let alone one that is functioning correctly. There is absolutely nothing software related that would cause the iPhone 5 to get hot and not hold a charge. This is definitely a hardware issue, once that can only be corrected by a replacement. I'd set up a Genius appointment asap and explain the situation. I'd be shocked if it wasn't immediately swapped out at no cost to you.
Good luck and be sure to report back.
FuelieNova
Aug 3, 2008
636
33
I have an appt for 2pm tomorrow. I just hope they have phones in stock, when they replaced this one it was the last one they had! Good thing is it has Applecare and is still under warranty.
Thanks guys
Tom
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Thanks guys
Tom
Really? They should have replacements. they have phones used only for replacements. You'll only get the phone. You're not getting the whole box with accessories.
Sent using iCafe app
FuelieNova
Aug 3, 2008
636
33
Just go back from Apple, it had an error 2001 which they said was a hardware issue. The replaced the phone and all is good. I will say I love iCloud backup and restore!
Tom
