iPhone 5 ios 7.0.4 big problem please help
mony_nana
Dec 31, 2013
14
please help me to active it or bypass the activation screen or hackactivation
it gives me device unknown
please see the photos in the attachment
28,365
5,506
Thread moved. Please start jailbreak-related threads in the proper forum. You'll have to use mobile Safari to access this section.
mony_nana
Dec 31, 2013
14
i didn't that i just run the both programs just the be sure they can detect the phone
i saw you what Evasi0n the device must be active first
mony_nana
Dec 31, 2013
14
i cant bybass the activation screen to use anything
mony_nana
Dec 31, 2013
14
i restored it many time as you say
how can i set it up as a new device and you see the iTunes error
and what you mean by start from scratch
mony_nana
Dec 31, 2013
14
i tried but after restored it need to activation and the jb will not work until it active first please check the photo
I restored it many time as you say
how can I set it up as a new device and you see the iTunes error
Enter DFU mode (device firmware update).
  1. Plug your device into your computer.
  2. Turn off the device.
  3. Hold the Power button for 3 seconds
  4. Hold the Home button without releasing the Power button for 10 seconds
  5. Release the Power Button but keep holding the Home button
  6. Keep holding the Home button until you are alerted by iTunes saying that it has detected a device in Recovery Mode
Then it will re-install iOS 7.0.4 and you can set up as a new iPhone. Then JB
28,365
5,506
Activation shouldn't be a problem with the way the unlocks work now. Is your phone factory unlocked, did your carrier unlock it or did you buy an eBay IMEI unlock?
mony_nana
Dec 31, 2013
14
all what you said is ok but its also stuck on device unknown
i think the only way to build an ispw but until now i don't know how also i get the 2 programes to do that but they need a key sn0wbeerez and ultrasn0w 2013
mony_nana
Dec 31, 2013
14
i am in egypt and its from usa but not AT&T itss for verzion
28,365
5,506
Have you ever restored this phone before? I'm not certain, but you might not be able to activate a Verizon phone in Egypt even though they do work with any SIM out of the box.
