iPhone 5 shows LTE when on WiFi
EverythingApple
Jul 28, 2010
3,864
225
North Jersey
I tried a hard reset and still there. I'm jailbroken on 7.0.4 but haven't added any tweaks or themes. This just started. I did update several tweaks a few days ago. Any ideas? Help? Thanks!
EverythingApple
Jul 28, 2010
3,864
225
North Jersey
No, it's AT&T.
I disabled Springtomize 3 - iOS 7, resprung and it's back. I'll try to re-enable it and see what happens.
5,578
Reset your network settings.
5,578
I meant to say by disabling Springtomize, it's ok now. I'll try what you said than re-enable and hope it doesn't come back.
Check your Springtomize carrier and WiFi settings and make sure neither have a custom setting. You might have a WiFi image that isn't compatible with your device so it can't show it and is thereforee just showing the carrier.
EverythingApple
Jul 28, 2010
3,864
225
North Jersey
No custom setting. I reset network settings, re-enabled Springtomize, resprung and everything seems okay for now.
Edit: It came back, so I disabled Springtomize again and it's ok.
5,578
It sounds like Springotmize is conflicting with something - perhaps Zepplin.
5,578
Do you have anything else that modifies various elements of the status bar? I'd start with them.
EverythingApple
Jul 28, 2010
3,864
225
North Jersey
I removed StatusWeather and everything seems fine. I'll give it several days than either leave it the way it is it put Springtomize 3 - iOS 7 back and hide some status things.
