iPhone 5 shuts off
Nur2652
Aug 1, 2010
114
I'm having issues with iPhone 5, the phone has been turning off with 10, 15 % battery, I'm taking it to Apple store next week. Other than that is there anything I can do on the phone itself? Thanks.
Sent using iCafe app
djwindsor
Jul 7, 2009
755
44
Neponsit, NY
I had a similar problem. More than likely it is a bad battery. Try and re calibrate a few times. If that doesn't work, go to the Apple Store and have it diagnosed. Keep in mind that you should make an appointment with a genius. You. can make the appointment on your device using the Apple Store APP.
