iPhone 5s 7.0.4 JB...need new phone HELP
ironlungakc
Aug 26, 2007
94
Hi,
I have an iPhone 5s 7.0.4 JB.
screen cracked so I want to use my Applecare to get a new phone. If I do get a new phone, can I restore from backup and stay at 7.0.4 so I can JB or will it automatically make me put the latest software (7.1?) on the phone.
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
If your new iPhone comes with 7.1 or later, you're out of luck. A 7.0.6 backup won't matter.
If your new 5s comes with 7.0.6 or earlier, you're golden. Just use evasi0n to jailbreak and restore your 7.0.4 backup.
ironlungakc
Aug 26, 2007
94
I realize this. I guess my question is if I get a new phone now, will it come with 7.1?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
There's no way to be sure. It could all come down to whether or not your local Apple store does a brisk businesss with quick product turnover. I've heard of folks getting 7.0.4 just a few days ago, but you could very well end up with 7.1. Just make sure you tell the Genius (or whoever) that you prefer to update the new iPhone yourself. At any rate, your new iPhone will not automatically update. Good luck!
28,365
5,507
When you call to make your appointment, ask if that store is doing on-the-spot screen replacements. Many of them do. If they are, take your phone to Apple while it is jailbroken. You have a good chance of them overlooking the jailbreak.
