Iphone 5s gets switched off at 8%
rugved1118
Sep 27, 2013
639
Hello,
My 2.5 yrs jailbroken 8.3 iphone 5s gets switched off at 8%. Can anyone please help me diagnose this issue ?
Also, when kept for charging, the apple logo is displayed in just 1-2 secs and 7% charging is displayed.
Please help !!
28,365
5,506
This has happened occasionally to me on all of my iPhones. It's nothing to worry about if it's just once in a while. It could be that the battery percentage wasn't calibrated. Rebooting typically resets that. Post back if it is happening every time you get to 8%.
rugved1118
Sep 27, 2013
639
Yes. This is happening every time. Please suggest !!!
rugved1118
Sep 27, 2013
639
I have tried pressing home button and power button at a time until the apple logo is been displayed, several times. But the issue still persists.
28,365
5,506
I don't think you can do anything to fix this aside from restoring or getting a new battery. You could try resetting all settings.
rugved1118
Sep 27, 2013
639
Hello Europa, after resetting all settings, my cellular data is not functioning. I am able to receive and attend calls. After checking the settings tab, i found this
rugved1118
Sep 27, 2013
639
Wifi works fine. I cannot call Carrier because I do not have APN setting tab visible. Also, why is my number not displayed ?
28,365
5,506
Call your carrier and let them know you don't have cellular data or an APN setting tab. If they can't help you, you might have to restore.
Napoleon PhoneApart
Jun 19, 2007
33,449
4,536
Upper Marlboro, MD
My bad luck.... I did not backup my iphone previously. It worked great on my 5s running iOS 8.4.
So, I have no other option than to Update.
Have you tried Cydia Impactor? That might work without having to update your iOS version and lose your jailbreak. It's worth a shot.
It's on the Cydia/Telesphoreo repo (http://apt.saurik.com/)
rugved1118
Sep 27, 2013
639
Phew !!!!!
Checking out Cydia Impactor just slipped from my mind. But many thanks for reminding me.
I have already initiated update so am helpless now.
