iPhone 5s, not responding
S
Sabis
Guest
Alright, I have some problems with my iPhone 5s after I've restored to factory running iOS 7.1.1.
When I turn on my own home wifi it's having trouble connecting. This never happened, not sure why its happening now. I have to reconnect 4-5 times, plus browsing isn't fas
When I keep my screen on lock mode, the passcode part...it should turn off by itself in 10seconds and it doesn't.
I did hard reset then its fine and i keep lock 1 minute. It doesn't lock at 1 minute, I have to hard reset most times and iPhone 5s is slowing down, its touch and everything.
Dec 15, 2008
5,386
340
Pensacola, FL
To get 1 question answered for the time being, did you use a backup after you did a factory restore?
28,413
5,544
Settings > General > Reset > Reset All Settings
S
Sabis
Guest
OKay..Another question and its important.....im not sure if its available in Abu Dhabi but anways...
is there a anti-glare screen protector or a protector for your eyes tht acts like a screen protector for iPhone 5s?
having eyes problems..
28,413
5,544
These are good ones. Check Amazon, eBay and other vendors to see if they ship to Abu Dhabi.
http://www.spigen.com/iphone-5-screen-and-body-protector-set-steinheil-ultra-crystal-mix.html
http://www.amazon.com/iphone-Screen...rprint/dp/B00FN6BED8/ref=cm_cr_pr_product_top
