iPhone 5s restarted, went into safe mode?
Status
Not open for further replies.
S
Sabis
Guest
I'm worrying about my phone as i don't know why this happened, I switch on my phone was shooting some pictures and it auto restarted...so that's worrying me.
28,365
5,506
Agreed. Uninstalling your camera tweaks should fix it.
S
Sabis
Guest
I didn't download any camera tweaks, i just reinstalled my latest tweaks about a broadcast stuffs like that.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I didt download any camera tweaks, i just reinstalled my latest tweaks about a broadcast stuffs like that.....nvm problem solved...you can remove this thread.
Was it a tweak or something that caused the issue? Maybe telling us what it was will help others out.
S
Sabis
Guest
OK guys i got another problem in my iPhone 5s.......
I've download Dr.Driving from Apple Store...u can check it out yourself it's free. After I jailbroke my phone, it keeps crashing the moment I open it.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Ive download Dr.Driving from Apple Store...u can check it out urself its free.....after i jailbreaked my phone its keeps crashing the moment i open it...
This specific app crashes or do any other apps that you have crash?
Have you installed anything via Cydia since you jailbroke?
28,365
5,506
Delete Dr. Driving and then reinstall it.
S
Sabis
Guest
Hey Chris, please accept my apology sorry.....
S
Sabis
Guest
Guys...im having a problem which i believe started after i jailbreaked.....i download some games for free from App Store...like this one Dark Guardians, and some cricket games....the moment i open it it it crashes ......... can someone help me...
It should play high games....its 5s
Dec 15, 2008
5,386
340
27
Pensacola, FL
Have you installed anything from Cydia after jailbreaking?
Have you tried a reboot of your iPhone, and a hard reset or respring?
S
Sabis
Guest
Yes, ive downloading tweaks not related to these games though, and ive tried reboot,hard reset,respringed.....also reinstalled them and same thing re-occurs.
So its something related to Cydia, pretty much sure...or errors etc.
28,365
5,506
Please list your Cydia apps and tweaks so we can try to determine if one of them is causing this.
S
Sabis
Guest
Sure.
Thanks guys for helping me out...
S
Sabis
Guest
If there is anything else that you want, Id be glad to upload them immediately.
28,365
5,506
You're using software that supports app piracy. This is what is causing your problem. We are against stealing apps here and we do not provide tech support for problems caused by software that supports that. Continuing to discuss piracy will result in an infraction. The only advice I can give you is to restore and not install cracked app software afterwards. Thread locked.
Status
