iPhone 6 Bendgate
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Not sure what to make of these photos or reports. It's hard to tell if the phones were subjected to stress tests beyond what is reasonable.
And this video, because now we've transitioned from blending and concrete to bending.
Hard to say right now if this is a real issue. If you're telling me that you can't reasonably pocket your iPhone 6 or 6 Plus, I could see that being problematic. I'm already crazed about not dropping it, that I've used my pocket more often. If the pocket is no longer a safe haven, I'm screwed.
Original report at MacRumors, with story as to why these bends allegedly occurred.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Just a postscript to the video. To me, it looks like this phone is already bent before he even conducts the test. As for the stress, it seems to be well beyond what should be acceptable. I would expect any phone to break.
jaydoc1
Sep 23, 2007
608
Happened with the 5 and 5S too, I believe.
Torinate
Sep 19, 2009
325
Eek!
I'm a regular pocket user... Guess I can't have it there if I'm planning on doing anything that requires any real physical movement.
Any response from Apple?
Previously, was there any warranty for this?
Wonder if a plastic back (5C type) would be more durable...
imutter
Apr 4, 2011
5,983
776
Somewhere between DC and Baltimore.
I just saw this too, I have carried my iPhone 6 since Friday morning either front or back pocket in my Jeans, I was in NYC so all day sitting standing walking.Mine is straight as it should be. Wonder if this is a issue with most bigger thin phones?
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Those cases cited by that site are extreme damage cases. The real question is, just how much stress did the wedding guy do to his iPhone 6 Plus. I'm sufficiently freaked out. I've been so stressed out over possibly dropping the Plus, that I've been pocketing it early and often. It seems ok. I've got a heavy duty Supcase getting delivered tomorrow. That's the end of its days in my pocket, for now.
Again, I don't know what to make of the claims. All I know is that is sounds plausible and I don't want to be that guy who bends my $900 iPhone.
imutter
Apr 4, 2011
5,983
776
I so agree. I do not know what to make of this? But since the announcement of the PLUS I had said I can not put it in my pockets.
I had the Oneplus and experienced how uncomfortable it can be and easy to just slip out of the pockets while moving and sitting down. I also looked again at the store at the Plus and while it feels not big at all, again I tried to pocket it and just knew this is not working for me. How they bend it I have no clue? Perhaps it depends on body size ?
JWiPhone
Sep 18, 2007
6,358
448
Los Angeles, CA
I find it hard to believe that regular pocketing would bend an iPhone, unless other stressful factors are involved. It may not be other people's style but I wear a belt holster for the iPhone where it stays protected and out of the way. I never liked putting my iPhone in my pockets because I carry so much other stuff in my pockets.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Maybe, we just don't know. That video shows an extreme amount of force. How much pressure was applied in their front pocket? I would think it would enough to think, hey maybe it's not a good idea to keep my phone in my pocket.
Seems the bigger, thinner frame of the iPhone 6 Plus does make it a viable candidate for this sort of damage.
iksn
Aug 7, 2008
717
Near Las Vegas
I don't buy it. I don't believe pocketing it will damage it and I don't believe a case would protect it if that was the case (wow pun city USA).
My plus will reside in my left front pocket caseless as always.
Chancellor
May 28, 2011
278
25
It does show a high amount of force,but I could see that happening when getting in and out of my car. I used to be super worried about my note 3 breaking in my pocket. I originally ordered the plus but ended up with the 6, I don't have to worry about it either way ;).
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Godspeed and good luck to you. :)
liberated
Jul 19, 2007
3,238
488
This is absolutely plausible apple probably did not intend for this phone to be a pocketable item. I am glad I got the 6, nevertheless I am using a case for daily use for the first time ever on my iPhone because I thought the device was way tpoo thin and slippery, perhaps the case can help prevent the bending problem. How long until we see cases marketed to specifically prevent "The Bend"???? :D
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
iPhone 5 and 5s models were known to bend, too.
liberated
Jul 19, 2007
3,238
488
Use a stiff case until this is sorted out
iksn
Aug 7, 2008
717
Near Las Vegas
yes, ip5's and 5S's were probably bent in a vice and i'm sure the 6's could be, but I really don't see a phone that is flat against the front of my left leg bending. The part against my leg is protected from bending. I've had my case-less phones there for years.
Having said that, the video makes me cringe.
Aug 1, 2007
1,232
44
I can see Apple's response to this: "Don't put it in your pocket."
Flashback 2-3 years ago: Antenna gate problem. "Don't hold it that way."
If this turns out to be a real issue: I really hope Apple does a recall. This is truly unacceptable if people are just putting it in their pockets. A little bend is okay, but the way his was before he bent it was sorta painful to see.
I'm glad I have the 6 right now, but I still want to go to the AT&T store and swap my 6 to get that plus when they have them in. :O
