iPhone 6 plus battery readings
Kazman
Dec 27, 2007
46
My iPhone 6 plus battery gives me different readings after a full overnight charge, I can unplug it when I get up in the morning and it says 100% then I will shut it down and restart it for the day but when it boots back up the battery say it's only at 99% so I plug it back in but it just sits at 99%, the only thing I have found that gets it back to reading 100% again is to unplug the phone and reboot it again, I have done 3 restores and set up as a new phone each time, has anyone else noticed this, or experienced this too?
silvermoon
Jul 17, 2013
1,624
179
Washington
Hmm... I haven't had this happen before, what I might suggest is let it drain for awhile. I usually let me phone drop below 50% and then charge it back to full and sometimes I leave it on the charger overnight because the iPhone has built-in protection that prevents the battery from overcharging. If that doesn't work and it is still giving different readings, you might consider making a Genius Bar appointment.
Njshoremom4gurlz
Sep 13, 2011
536
84
I would go to zero let it die and try to bring it to 100% (calibrate it) if it never gets to 100 i would go to apple.
I thought my battery was going way fast compared to the six i calibrated it twice fixed my settings and now it's kicking in perfect I charge once a day)
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
The problem is that my Plus has never reached zero!
Kazman
Dec 27, 2007
46
I have ran it down 3 times and it still does it every morning when I unplug it.
Feb 3, 2013
190
Basically smart phones nowadays really drain its battery really fast. But for battery life improvement try calibrating your phone. Hope it helps you. :D
ivantwilliams
Jul 14, 2009
1,546
218
I'm curious why after you've fully charged it, you then restart it before starting your day? Why not simply leave it on, and continue with your day?
Kazman
Dec 27, 2007
46
it will actually drop to 99% within 15 to 20 minutes anyway without any use if I just unplug it from charging overnight.
ivantwilliams
Jul 14, 2009
1,546
218
Posting image from last night (posting was disabled for the move to the new server)...
