iphone 6s plus dust in metal ring
alexrat1996
Jun 23, 2016
322
19
I have a iphone 6s plus I see dust on the outside of the metal ring at then of my temper glass screen protector how did the dust get in there is that normal after daily use and I posted photos below
I have found that there can be a couple of reasons for that. First, if the screen isn't completely clean when the glass is applied, it will lift a little at the edges and gather dust. The other times I have seen it is with off-brand glass protectors that simply don't adhere well. I had it happen with a cheap one that I bought on Amazon and it lifted at the edges after only a few days. I have had good luck with the major brands including Zagg InvisibleShield (a bit pricey) and recently with NekTeck, and it is only $4.99!
alexrat1996
Jun 23, 2016
322
19
This is inside the metal ring but the outer part of the metal ring is more visible if I tilt my iPhone.Its near the end of the screen protector what can I do to take it out and the screen guard from Amazon had 5 start rateing
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
A five-star rating on anything should never be taken as a guarantee that the product or service in question will be 100% satisfactory to you. You could always be in the unlucky 1% that gets a lemon.
alexrat1996
Jun 23, 2016
322
19
It's stuck inside the white part where the metal ring at but at the outside of the metal ring
Should I take to apple so they can clean it out
28,365
5,506
I'm surprised that screen protector isn't triggering your OCD. It's misaligned. It's touching the right edge of the Touch ID button. I would remove it, clean the Touch ID gently with a slightly-dampened cloth, order a Zagg screen protector and have someone at a Kiosk at a mall apply it. They'll get it on there straight.
alexrat1996
Jun 23, 2016
322
19
They tried to clean it with air compress in the back and another technican who fixes phone in the back took a look at it then genius tech told me won't affect my phone and home button and I did contact the person who I purchased the screen guard they sent me another one via mail
Good part about the appointment is they sent my power beats 2 wireless out for repair
