iphone 7 belkin glass issue
alexrat1996
Jun 23, 2016
323
19
I have a belkin glass on my iphone 7 installed at apple store oct 2016 then march 2 it had dust under it and I contact belkin for a replacement they told me once I get the new to go back to apple for them to install it.
Will apple reinstall it for me like belkin told me ?
Ohmster
Jan 26, 2008
533
21
SoCal
I guess you could just call the Apple Store and find out. If someone there says yes, make sure to record their name (just in case)....On the other hand, I've installed the Zagg protectors on more than a dozen iPhones. It's pretty easy and the Belkin Glass for Watch had a sweet fixture to ensure proper fitting. Not sure what the iPhone one comes with. I'm sure you could do it yourself with minimal risk.
alexrat1996
Jun 23, 2016
323
19
There sending me protector only without the kit they told me to go to Apple Store two belkin rep
alexrat1996
Jun 23, 2016
323
19
update apple installed it all wrong they caused dust under the screen protector Should I try a different apple store I had to install a 99cent one till I get a new one from belkin
RoofMonkey
Jun 21, 2010
8,891
2,057
Seriously... how is anyone supposed to answer that question?
You installed a $.99 one, why not install the one from Bellingham when you get it?
alexrat1996
Jun 23, 2016
323
19
i don't install them good I will try another apple store or belkin store
alexrat1996
Jun 23, 2016
323
19
For example I installed three screen protector on my iPhone 7 to get a perfect fit till I get a new when I install the belkin one won't it cause dead pixel or no ?
The only time I caused dead pixel was when I use the alcohol pads to clean screen but this time I did not.
Jun 19, 2007
33,486
4,549
Upper Marlboro, MD
Mod note: Post moved to this thread. No need to start a new thread related to the same issue.
RoofMonkey
Jun 21, 2010
8,891
2,057
You can't cause a dead pixel by wiping/cleaning the screen with an alcohol pad....
alexrat1996
Jun 23, 2016
323
19
I got a replacement screen protector apple installed it and a piece of hair stuck on it should I call Belkin again for a replacement or leave it in there
RoofMonkey
Jun 21, 2010
8,891
2,057
Did you bother to inspect it immediately after Apple installed it?
Yes i did but it's a replacement from Belkin not apple and apple installed it for me
So that means you didn't see the hair after the application and before leaving the store... it's not Belkins fault that someone else didn't install it flawlessly.
alexrat1996
Jun 23, 2016
323
19
Got it fixed apple installed a new one in the machine fixed
alexrat1996
Jun 23, 2016
323
19
Apple exchanged my replacement for the store one that works for the Machine can I use my original receipt of proof of purchase to continue ask replacement from Belkin when needed or do I need to ask for the receipt of the exchange they did at the store ??
