iPhone 7 home button
Zanthe
#apple
Aug 9, 2007
2,630
314
So with the iP7 and iOS 10 will you have to use the Touch ID print or have a pass code to make it work?
Right now I have neither but since there will be no slide to open I'm not sure what will be 'required'.
28,365
5,507
You can still use a passcode on iOS 10 on an iPhone 7/7 Plus. There's just a different way of invoking the keypad (press the home button) since the left slide gesture brings up widgets now. Also, if it doesn't recognize the fingerprint or it's it's been too long since you've used the phone or Touch ID, you'll have to put in a passcode just like we have to now.
bballrob
Oct 11, 2009
1,921
476
Alaska
Dayum. Even being on the beta, I hadn't made this connection.
But it's true. All of it.
Zanthe
#apple
Aug 9, 2007
2,630
314
So then it looks like you have to press the home button twice. Once to unlock and then again to get to your apps. No?
28,365
5,507
It will work just like it does now, except the button won't actually depress.
