iPhone acting weird
Apr 1, 2008
i noticed this morning that when i go to the home screen and touch one of the icons, the program will come up but then i cant do anything else. when i touch something after going into a program it doesn't register. also when it goes into sleep mode, it doesn't completely black out. it gets fairly dark but i can still see the wallpaper. any ideas on what i need to do? thanks in advance for any help.
Saverino
Jun 1, 2008
4,480
92
Burbank
Mine did the exact same thing. It worked after a couple of resets, but then occurred again. The only thing I did to completely make it stop was to restore. IMO, I think you should restore.
chcorey52
Dec 25, 2007
556
install kilboard and just use that to reset
Cusca
Apr 27, 2008
320
ROMANIA
www.cusca.3dk.org
usually when the iPhone starts to do stupid things like that, the best thing to do is restore rather then atempt to use other fixes that lead to other problems, but that`s up to you, for example my phone keept loosing service, i tried a lot of things that fixed the problem for a while but in the end i had to restore
iphonewarrior
13,847
701
put it in your mouth and bite it and tell it to behave itself!
ChArLiE713
Jul 3, 2007
149
What do you mean reboot? Restart the phone? Mine used to the same...I used to restate it once or twice and it worked, but now I waste the whole battery restarting the phone for it to work.
