iPhone address book dilemma
jayeden
Sep 13, 2007
17
here the situation
im coming from a blackberry - i did a backup of my blackberry, which is saved in a .ipd format
how can i extract the info out of the .ipd into outlook so that i can eventually sync a dress book i create with outlook to my iPhone
as well, is syncing my oulook address book with the iPhone even effective or will i spend hours cleaning crap up-
whats my best bet? is there a 3rd party program that creates a nice iPhone address book that i can sync? can i DL a add-on for iTunes that builds my contacts into there?
Please advise,
Jaye D.
geordisjd
2,442
here the situation
Please advise,
Jaye D.
I don't think there is any 3rd party program that does that. I had reenter all my contacts by hand. It was time consuming, but I enjoyed assigning them a pic and a home-made ringtone.
dgarza
Aug 18, 2008
wow is this the only way to do this?
RyanP
Jul 26, 2007
51
I'm not sure if this works, or if it's worth $20 to you, but it says it will convert ipd to any other format. You could convert it to csv and import it to Outlook like that:
http://www.processtext.com/abcblackberry.html
And unfortunately I don't know of any other way to sync contacts than Outlook (assuming you are on a Windows machine). I find it ironic given how anti-Microsoft Apple tries to be. I would love if they came out with a way to sync contacts and calendars to Gmail/Google.
iChristian
May 28, 2008
315
You can do it on an Address Book for instance if you have a Mac and put them on your computer. Or if you have another computer I'm sure there's an address book feature or email contact list where you can sync it to your iPhone. If you think its too complicated just do it by hand.
Jul 16, 2008
1,592
Colorado
You can sync contacts with Google just not calendars yet.
dgarza
Aug 18, 2008
got it done easily...sync my blackberry to outlook and then outlook to iPhone now all my contacts are good to go...took 4 minutes for all contacts...beats hand inputting them any day...
RyanP
Jul 26, 2007
51
I don't think this is true for Windows users (though it's supported on Mac OS X 10.5.3). I'd love to learn I was wrong on that, though I'm not having luck finding anything about it online.
RyanP
Jul 26, 2007
51
My apologies to MileHighRob! You can now sync contacts to Google contacts on Windows...that made my night. One more chain to Outlook cut...I'll keep my fingers crossed on the Google calendar syncing! Thanks, Rob.
Jul 16, 2008
1,592
Colorado
No problem Ryan. It's actually been an option for Windows users from day one.
