iPhone always runs on Edge even when connected to WiFi
seb481
Aug 3, 2007
774
San Diego
I have this weird thing happening...
When I'm at work for example, my iPhone is on our wifi networks but everyonce in a while the phone is gonna make my speakers do this funny noise (like tzz tzzz tzzz tzzzzzztzzzzz). I then look at the phone and it's actually on Edge when it should be on wifi. If i then open a webpage, it goes to wifi. I played around with all the settings I could think of but i still have the same problem.
My coworker has an iPhone too but his always stay connected to wifi while at the office.
Any idea what the problem could be?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Are both of you using the same settings like WEP or WAP? Talk to each other.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Also the noise you hear is the phone checking for email and is attempting to go on line. For what ever reason, mine sometimes goes off the wifi.
termleech
Sep 7, 2007
1,154
McPherson, KS
It will make that sound even using Wifi. I don't necessarily think it's because it's using Edge, it could just be part of the startup process for the Wifi. Mine does it all the time while I'm at my house on Wifi, but the Wifi kicks right in.
Prelector
Sep 6, 2007
151
That buzzing noise is from the CELL handshaking between your iPhone and cell tower network. All phones do this periodically to let the network know they are there and ready to receive calls. You might notice that same buzzing, just moments before a call is received and your phone rings.
As to the going off WiFi and onto Edge... I can't say for sure, but I'd guess it's your phone checking in for voicemail periodically. Remember, the Visual Voicemail feature always uses Edge to download any voicemail calls, so it has to periodically check in with Edge (even though it's a "push" system, the phone still checks in occasionally).
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
On my phone the wifi symbol only displays when I am in safari, email, or other application that is actively searching or bringing up data. If I return to the homepage on the phone it displays the E even though wifi is still active. I don't think that this indicates that your phone is turning off wifi or not still connected through wifi. You said that once you open safari it changes to showing the wifi symbol and is connected using wifi so I suspect yours is the same situation as mine and not an issue.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Since I turned the email to manual, it stays on wifi now. Even when I check for the email it stays on wifi, not switching to E to check so I do not know what to think.
