iPhone and a sound board
Oct 15, 2007
I have a sound board @ home and am currantlly using my nano to listen to through the sound board which I play drums along to so I think that the iPhone would be great because I don't know when a call comes through unless I check my old style cell phone....so getting a iPhone would be so great to have .....
Mar 25, 2009
BeefyBoard iPhone Soundboard
Check out BeefyBoard, it's an iPhone soundboard that lets you create your own soundboards and save them to your iPhone. It also works on 2nd generation iPod touch as well. The cool part is you can upload the soundboards you've created and download other peoples soundboards as well.
There is a built in drum soundboard, but you can also create your own if you want.
It also has skin support so you can create and upload skins at http://www.beefyapps.com and then swap out the default skins on the buttons to whatever you want (a drum skin for example).
