iPhone and Palmpilot
robhon
Mar 17, 2007
620
You wouldn't sync between the two devices. You'll want to check what you can sync from your computer to your iPhone.
What program are all your contacts in? What operating system are you working on? Mac/PC?
joe
May 5, 2007
1,113
Your two devices stay in sync by syncing them both to the same computer. I kept my phone, iPod, and computer in sync this way. Just think of the computer as the central device that has all of your info.
netshadow
Apr 21, 2007
40
Upstate NY
only one
It would be my hope that I would not need my Palm Tx after getting the iPhone. Then I would sync all calendar events and contacts through the Mac/pc. I am hoping to only carry the one device.
:eek:
joe
May 5, 2007
1,113
:eek:
Then you'll be able to do one last sync from your Palm to your computer, then sync it all up to your iPhone from your computer. :)
robhon
Mar 17, 2007
620
The problem may come if you kept all your calendar and contacts information only in your Palm Desktop. Then you'd have to do a sync between the Apple's programs and the Palm Desktop. Which I have done before but a long time ago. Not sure how to do it anymore.
Summi
Jun 14, 2007
Palmdesktop & iPhone
My problem is that I work with Palmdesktop and my problem is to bring all my data (only one time), appointments ad addresses (more than 500) from Palmdesktop, without loosing information's on the iPhone.
I work with a Mac at home with Tiger and with a PC at work with Windows XP. On the two systems I have installed the Palmdesktop.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
If you have all your data in Outlook or Outlook Express on the XP machine, you should be okay. I can't remember the mac program right off that will sync on the mac side.
