iPhone & Android
craiggiarc
Jan 20, 2009
421
32
I have an iPhone 4s on AT&T but would like to try an Android device.
If I buy one can I simply switch sim cards and jump between the two?
Thanks in advance
Craig
Yeah, but you'll have to pay full cost if you just bought your 4S subsidized from AT&T.
iP5
Sep 7, 2010
2,964
136
Toronto
There aren't any Android's using microSIMs, you'll need an adapter to frame to the standard size.
Sent from my Desire HD using Tapatalk
6,683
51
As others have said, you'll need a micro sim adapter.
Personally, I highly recommend going to a store and trying one out right there in the store before making any purchases. You might find you don't like the UI, or find that apps you use a lot on your iPhone are not available for the Android. Be smart about researching before purchasing.
  • Like
Reactions: TarekElsakka
Bennyboy
Jul 21, 2010
14,017
1,731
PA
I agree with hawk, unless you can afford it ofcourse. What's the return policy on the Android device you're trying to purchase?
