iPhone app that will mirror text messages on computer?
rom x
Jan 18, 2011
1,043
99
ok i need a little help. im going to friends house to help him with a few things on his iPhone. now most of the stuff he wants to do on it. i know how with the exception of 1. He wants to know if their is an app that will mirror his text messge on his computer. know i use mighty text with Android but i don't recall ever seeing and app for iPhone. does anyone know of such an app?
rom x
Jan 18, 2011
1,043
99
ok i have told him to check that diskaid out. also he said he has some text messg that were deleted but he says they are on the phone but are zipped up. is that true and is it possible to recover them?
and oh thank's for the advice on diskaid
28,365
5,506
ok I have told him to check that diskaid out. also he said he has some text messg that were deleted but he says they are on the phone but are zipped up. is that true and is it possible to recover them?
Yeah, it sounds like his phone was/is jailbroken. He can uncompress and restore the zipped SMS file if it is still jailbroken.
28,365
5,506
Hello Europa,
Would like to know whether iTunes backups up text and contacts also ?
Yes, it backs them up, but iCloud supports push contacts (instantly saves them in the cloud when you update them), so it's a good idea to toggle contacts on in iCloud and use it in addition to making iTunes/iCloud backups. Another advantage to this is you can restore to factory settings whenever necessary and sync your contacts back on without having to rely on a backup.
28,365
5,506
In that case, what is the difference between iTunes and diskaid ?
They are two different programs. Diskaid gives you access to the file system. However, it's only partial access when stock. The program is very useful when jailbroken because it allows you to modify system files and manually customize the phone.
rugved1118
Sep 27, 2013
639
So which program would suggest for a non-jailbroken iPhone5 ?
Sent using iCafe app
