iPhone Applications Installer
scrowner
Jul 4, 2007
120
Wow. That is sweet. I am waiting to read how everyone is liking this before I take the plunge. It is nice that it has updating built into the app. This makes it simple. Very nice.
teriyakiboy13
Aug 1, 2007
niceeee
but is there a way so when i update nes it doesn't delete the icon.png and default.png?
i like my icons and i don't want to have to change it everytime i update a app
Tinman
4,334
183
Aridzona
when I click in the install.zip file it says safari can't download....how do i do this?
You have to install this app first using the traditional app installation process (i.e., with the iPhone connected to a computer). Only after you have this app setup and running can you access other apps and install them via this app.
Mike
r00t4rd3d
Jul 22, 2007
53
Ive been using this program for about the past 12 hours and I think its great ! No need to be on wifi/vpn to install apps anymore ! You can install apps on the Edge network. Updates installed apps when new versions are released if you choose. Seems every hour there is a NES update and with this app , updating is a breeze ! New apps and web sources for app downloads are popping up every hour.
This app rocks , must have.
Notice the scroll bar , this list keeps growing !
:D
x999x
Aug 6, 2007
1,656
:D
Wow, how come my app list only shows the BSD as being available?
onendonlysean
Jul 7, 2007
yes how come u have a lot of apps? is it b/c u added soucres? all i have is BSD subsystem, community sources, doom, launcher and mobile terminal...
Napoleon Dynamite
May 20, 2007
103
30
Turin, Italy
www.connessionegratuita.com
:D
What are Finder and Mobilefinder made for? :)
r00t4rd3d
Jul 22, 2007
53
Install the community sources and update it if there is a update under updates lol.
Community sources = where the apps come from.
Tinman
4,334
183
Aridzona
Would this and other installations be for people with more technical knowledge or is it pretty easy to do? Any feedback would be much appreciated.
Don't know about on a Mac, but it's not that hard to do on a PC.
All you have to really do is follow these (somewhat easy) tutorial:
1.) Easy unlock instructions for Windows:
http://hacktheiPhone.com/iPhone_first_ten_steps_to_modding_windows.html
Everything you need to download is right in the above tutorial, plus instructions on how to do it.
2.) Easy instructions to install SSH:
http://hacktheiPhone.com/iPhone_install_ssh_windows.html
3.) Easy instructions to install this (Installer) app:
http://hacktheiPhone.com/iPhone_using_installer_app_windows.html
That's it. Once you get intaller.app installed you should be able to use it to install and update other apps. Of course once you get this far you should be able to install apps directly too (without installer.app).
Mike
lymn
Aug 8, 2007
40
We need some kind of repository to be set up, so we can turn this into an iPhone version of app get.
Sell224
Jul 5, 2007
This may sound really dumb.. but I had downloaded this program last night with the intention of putting it on my phone today. This morning I forgot which program it was and renamed it "Lights Off" (thought it was the game). I installed it and it installed well, but I realized it was the installer program, not the game.
Now I have an icon called LightsOff on my phone. It wont let me delete the folder or rename it. What do I do?
