iPhone apps downloader
jp7
Oct 24, 2007
I have an unlock phone running 1.0.2; on the main screen I had an icon apps downloader. As I added more applications and the screen filled to 16 icons my "apps downloader" icon disappeared, because on the main screen does nor scroll down.
I need apps downloader icon to add and remove apllication.
Help
jp7
patrick_83
Oct 11, 2007
310
Illinois
If you are on a PC then DL iBrickr to you PC then get the where it says install PXL or something like that, or if the phone has PXL then it should say applications somewhere, click that then scroll till u see Dock. Install Dock it will allow you so see all of your apps. Once you can see installer again open it up and then install Summerboard, problem solved.
If you have a MAC the DL you need is Breezy i think but not sure if its spelled right, and i don't know how to use it.
hankremix
Oct 24, 2007
get xlauncher for your iPhone from app installer... It manages your springboard by either hiding the unused icons or squeezing it to the dock
typer922
Jun 7, 2007
86
I don't think he can do that since the OP said Installer had been moved off his springboard and he can't scroll down to it
