iPhone Backgrounds: Color Variations of the Weather App
princess_80854
657
I decided to post some color variations of the Weather app background to compliment some of the existing themes out there. Hopefully someone will find these useful.
First, you'll need to rename the backgrounds to:
weather_day_bkgd (AND/OR)
weather_night_bkgd
Then make sure you put them in your "Modding" folder.
To install using iPhoneInterface, input these commands: (according to which backgrounds you are changing)
cd /Applications/Weather.app/
putfile Applications/Weather.app/weather_day_bkgd.png
putfile Applications/Weather.app/weather_night_bkgd.png
To install using ManzanaUI, drag and drop backgrounds into this folder:
*******QUICK NOTE*******
You DON'T have to restart your phone in order for the changes to the backgrounds to take effect. Just open the weather app and you'll see your new background. If you had the Weather app open while you were installing the new background, just close and re-open and you'll see the changes.
ENJOY!
Witness
Jun 18, 2007
1,471
26
Miami,Florida
cool have you figuredout how to change the background of the settings menu?
marauderrt10
Jul 23, 2007
95
No, there's no visible file that we can edit for that one. I really wanted to change it too!
Actually princess there is! Its called Default-prefs.png. Heres the file! So start editing! :laugh2: Can you make it that dark red color (same as the 3rd one on your weather ones) Is it possible to keep the lines going down?
princess_80854
657
I'm aware of that file. But the phone won't allow you to change it.
princess_80854
657
you sure? Its viewable in manzana so it should be able to work.
There are a lot of files that are viewable in the Manzana UI application that can't be overwritten for whatever reason. That one is one of them.
reebs
Jul 11, 2007
146
thanks princess, awesome!:laugh2:
propedderkustoms
Jun 30, 2007
45
I renamed one of them Default.png to replace the initial image that pops up with Weather loads; however, the image comes up as too large - I need a different image for Default.png in the Weather app. Any ideas? Thanks
propedderkustoms
Jun 30, 2007
45
Sort of solved my own problem. Made a 320 by 480 transparent image and put the colored Weather background in the right spot on it [took a couple tries to get it perfect]. Here is my final result for the red one...everyone can just use mine as a template and put their color over the red one.
PS, the background of the PNG is transparent but it shows up as black on the ImageShack link, but don't worry it is transparent.
princess_80854
657
Which background are you trying to use?
EDIT..Ok, this is weird! That's what I just finished doing. What size did you resize your background to? Mine is 266 by 310 on a 300 by 378 tranparent background.
propedderkustoms
Jun 30, 2007
45
I used a 320 by 480 transparent background, and put the Weather skin [exactly as you posted] on that. I had to move it around a bit so that it was in the exact right position so that when the Weather app loaded, I didn't see a "shift" from the Default.png image to the weather_night_bkgd.png or weather_day_bkgd.png image.
princess_80854
657
You did a a good job with that!:)
