iPhone browser?
eTEK
Oct 7, 2007
45
uhh is there a program other then iPhonebrowser out there that will let me put stuff on my iPhone other then iTunes?
iPhonebrowser doesn't seem to work for my vista laptop so =/
i need something that will work for both xp and vista.
termleech
Sep 7, 2007
1,154
McPherson, KS
Is your phone jailbroken and does it have SSH installed? If so, you can use WinSCP and connect to your iPhone through sftp.
eTEK
Oct 7, 2007
45
haha no its not. im to scared to do anything to my iPhone.
termleech
Sep 7, 2007
1,154
McPherson, KS
I wouldn't be scared to put third party apps on there. They works great and with the new installation I really haven't seen any issues. I'd give it a whirl :)
bigmac
Jul 13, 2007
110
Los Angeles
I have open ssh and iPhonebrowser, but I cant see ALL my files on my phone... what am i doing wrong?
Vista? You kiddin'?
Kidding. Use WinCP.
truehybridx
Oct 31, 2007
40
is there a better way to do it.... per say through usb
n im trying to look for iPhonebrowser just to test it out but i cant find it lol
n i personally don't like ibrickr's poor file manupliation
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
First, I use iPhonebrowser on Vista and it works fine as long as your on a 32bit system and not the 64. It tells you that it is not compatible but lets you continue anyway. Works fine.
bigmac, let me guess, you are on 1.1.1 and you used the jailbreakme site to jailbreak your phone? If so, you probably only see DCIM and a few other folders. Correct?
5,580
The sms.db file is located in /Var/Mobile/Library/SMS
canamera
Dec 28, 2009
2,756
79
43
Toronto Ontario, Canada
Thanks Europa... And don't worry Naps, I know you got my back, when know one else does!
