iPhone chargers are poor quality
hmfc-1874
Sep 10, 2011
510
34
Honestly I have went through dozens of them and this is just my one year old iPhone 5 on its own.
Bought one from asda tonight £17
But it's a coil type wire (like old phone wire) so hoping as this is thicker it will be stronger and last me longer.
How many have you used with current iPhone ?
Sent using iCafe app
28,422
5,548
I've never had an Apple cable go bad. I had a 30-pin that I used for years and it got a little frayed because I used it while charging a lot and that puts stress on the end of it, but it still worked fine.
Are you referring to official Apple cables? If so, Apple will replace them for free if they fail.
Dec 15, 2008
5,386
340
Pensacola, FL
I had an Apple cable that I used since I got the iPhone 5. It lasted me up until two months ago when it started to only charge at certain angles, holding the iPhone in certain spots. So of course I stopped using that one and got a new cable.
hmfc-1874
Sep 10, 2011
510
34
Mine practically last forever. What are you putting yours through?! :p
Nothing haha, I always have it on me in pocket.
I have no clue, the cable jacket comes off then the wires are not protected and stops working.
Rage :p
Dec 15, 2008
5,386
340
Pensacola, FL
Rage :p
I sure hope that they are Apple made. I made the mistake of buying mine off of eBay for cheap, and not fully reading the description. One of them the cable jacket came off, showing the wires.
hmfc-1874
Sep 10, 2011
510
34
I've never had an Apple cable go bad. I had a 30 pin that I used for years and it got a little frayed because I used it while charging a lot and that puts stress on the end of it, but it still worked fine.
Are you referring to official Apple cables? If so, Apple will replace them for free if they go bad.
Yeah but currently there is not a store yet where I live, would have to train it through to Glasgow haha.
But thanks when the Apple shop opens here then I will do that as I never knew.
hmfc-1874
Sep 10, 2011
510
34
Yeah I has 4 offical ones all same thing happens :/
28,422
5,548
I'd start looking at how you are carrying/handling them. It's not normal for them to fail like this and certainly not that fast. You are exceeding their stress limits.
iP5
Sep 7, 2010
2,964
136
Toronto
Only thing I don't like is that the casing is designed to fade to an off white.
Sent from my Nexus 4 using Tapatalk
RoofMonkey
Jun 21, 2010
8,891
2,057
These are my original 3GS cables... Guess it's all in how you take care of them & how you unplug / plug them :D
28,422
5,548
I've found that the key is to not use them in a way that it puts stress on the portion of the cable that connects to the Lightning or 30-pin when it's charging. You can use it while charging, but it will eventually begin to fray if that is bent a lot. But yeah, I have a cable that I've used since 2009 and it still looks new.
Dec 15, 2008
5,386
340
Pensacola, FL
Although mine right now are not Apple made, I think this plays a part in mine as well. The part of the cable that holds the square part and connector is being bent, thereforee causing it not to stay in charge.
I've never had a cable go bad until recently. My cord I had that came with my iPhone 5 stopped working. It wasn't damaged or split anywhere it just wouldn't charge unless I taped it. I feel like the older 30 pin ones had more space to grab and actually the older ones had little tabs to push in before pulling out of the device. The new lightning cables have very little to grab. With my big dumb hands it's easier to just pull the cord out of the phone from about 3" down. I feel like maybe that's why my 5 cord broke? Either way Apple replaced it..
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
I'm late on this thread, but I wore the heck out of my iPhone 4 cable. It started to fray and I taped it with electrical tape. Then the fray continued down and I added more tape. The fraying continued until 3/4 of the cable was taped. Then I upgraded to the 5. The 5 cable seems better made. I do use my phone a lot while plugged in charging. Is there a 12 step program for Smartphonaholics?
Sent on iPhone 5 using iCafe app
28,422
5,548
Do you live near an Apple Store? For future reference, they will swap them out with a new cable for free.
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
Thanks! I didn't know that. So far the 5 cable is holding up well.
iPutz
Nov 20, 2012
962
184
43
72
US Midwest
It seems like it all comes down to two things:
First, you get what you pay for. If you buy for cheap you get a cheaply made product that will either not work as expected or will fail quickly.
Secondly, how you treat the cables. Continually pulling on the cable to unseat the connector will cause the cable to fail at the juncture between cable and connector in a short time.
However, I have to agree with Muckcityjustin, people with big fingers have a much harder time removing the connector since there is not much to grab onto besides the cord, especially if you have a bulky case on the phone like an Otterbox. The Lightening connector is somewhat better in this regard vs. the older 30 pin connector but making the hard plastic shell 50% longer, on the lightning connector end, would go a long way toward making it easier to remove the connector from the phone and would surely reduce the number of cable failures for a very small cost.
Dec 2, 2013
I must say the predominant issue for me is bending and deformation of the cable right where the plastic shielding ends on the iPhone side.
Despite the fact that Apple lengthened the thicker plastic part with their Lightning chargers, I just find it now bends and deforms as soon as the thick insulation ends...
