IPhone Contact Search
Alkali
Nov 1, 2010
243
Nigeria
My friends,
When I open Contact App and wants to search for a contact the contact search does not work. Suppose I search for "John" by writing "Jo" it will return empty field. Please help. I have iPhone 6s with the latest iOS.
iPutz
Nov 20, 2012
962
184
43
72
US Midwest
What have you tried so far to correct the problem?
Alkali
Nov 1, 2010
243
Nigeria
I did almost everything there is to do.
1) went into settings check spotlight search, contacts is already checked.
2) somebody mentioned check and uncheck group contacts but unfortunately I do have that option.
iPutz
Nov 20, 2012
962
184
43
72
US Midwest
Did you try a hard reset? Holding down the Home button and the Sleep/Wake button at the same time for about 10-15 seconds until the Apple logo appears then let them both go. When the phone finishes rebooting try searching for a contact again and see what happens.
Alkali
Nov 1, 2010
243
Nigeria
I have done that over and over again and that may not be the problem.
5,578
Try unsyncing your contacts and syncing them back on.
Alkali
Nov 1, 2010
243
Nigeria
Europa I am using Google sync. It serves all my phones including Android and windows.
5,578
Go to Settings > Mail, Contacts, Calandars, tap on your Gmail Account, and then toggle off contacts. Select "Remove from iPhone" when it asks. Then reboot and toggle it back on. Test to see if you can search for contacts after the reboot.
Alkali
Nov 1, 2010
243
Nigeria
Darling Europa you are a life saver! Thanks very much. What are we going to do without you
