iPhone Crashed ?
abuzaid
Mar 16, 2008
Hey! Bro
Last Night I was using my iPhone, due to the slow speed i decided to remove unnecessary applications.
So after I remove all the foolish apps, tehre was a message to restart your phone. When I restart my phone, it work no more
It got frozen on the main screen where the "slide to unlock" message is displayed and keep on searching signals
i have restarted it so many times but failed to turn it on.
please tell me what should i do know
The message you received is the one received when you uninstall SummerBoard - what allows background wallpapers, themes, etc. The message also states that after the uninstall you may be unable to launch Third Party Applications - your problem may be a result of it as well. I suggest restoring. Sorry.
- John
abuzaid
Mar 16, 2008
i have also tried my iPhone to connect to iTunes but failed
but it got frozen at main screen as Apple logo disappears
so i am unable to connect it with iTunes
Bro, please tell me how could I connect it ti iTunes
You'll have to restore it, put it in recovery mode.
"Turn off your iPhone by holding the "Sleep/Wake" button for about five seconds and then sliding the red slider. If your iPhone is already off, there's no need to turn it on and then off again. Once it's turned off, press and hold the "Home" button and plug the iPhone into your Mac or PC. Keep holding the "Home" button until you see a yellow triangle and text which says "Please Connect to iTunes". You can now release the button. Open iTunes (if it's not already open) and you will be told that "iTunes has detected an iPhone in recovery mode". Click "OK" and you will be taken to the iPhone pane. Click restore and you're done. Depending on the extent of your iPhone's ills, it may take some time to do a full restore. Once you're done, however, you should again have a perfectly working iPhone." - iPhonealley.com
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
place in recovery mode..do a search on here for that or follow directions provided above
abuzaid
Mar 16, 2008
i have tried this restoring method as you quoted but once again unable to use my phone
Whenever i restore my fone, it works for a while but as soon as i restart my fone, it again got frozen again.
I am fed up with my ifone.
The Apple
3,105
Indiana
sell it to me for $25! Since you are fed up with it of course!
abuzaid
Mar 16, 2008
very funny......
Dear, i want some proper solution for this problem
15,384
1,089
if you're out of options, there's always the Apple store.
abuzaid
Mar 16, 2008
I am from Pakistan, i can't take my phone to Apple store
You ppl please tell me from starting what should i do to restore my iPhone(not working properly , always held) to factory setting
