iPhone Data Cable Coming Apart
Discussion in 'iPhone Cases and Accessories' started by ashwini, Jun 2, 2009.
  1. ashwini
    ashwini Member
    I got my iPhone 3-4 months ago. Now, the data cable is breaking from both the sides and exposing the wires. I can still use the cable but I am scared if I will end up breaking it into two!
    Is this covered in the warranty? I don't remember ever handling it roughly.
    [​IMG]
  2. Neo-Tech
    Neo-Tech Member
    I don't think it's covered by the warranty as it's wear and tear and it costs about £12 for a new one. I've got the same problem apart from it's the USB side. Cheap cables ftl :(
  3. Avatar
    Sponsored Advertisement
  4. Mine is worse than that, ashwini...:)
  5. ashwini
    ashwini Member
    @Napoleon - Does it still work??!
  6. Works fine. Yours should work for a long time as long as you're aware of the condition that's already there.
  7. Sharunda
    Sharunda Genius
    Yeah, I have about three that are bad. It's funny no matter if that white plastic comes off it still charges. But I have extras so I use them when mine got really bad looking.
  8. As long as the wires are intact, you're good.
  9. ashwini
    ashwini Member
    That should do, but you would expect someone like apple to put in a little more care into it!
  10. Europa
    Europa Moderator
    I don't think it's typical. I have several laying around from all my various Apple devices, none of them are damaged like that. At least they're cheap to replace.
  11. styfle
    styfle Zealot
    If I were you, I would put some electrical tape around that to prevent it from ripping anymore. It might look stupid but it will work.
  12. iphonewarrior
    iphonewarrior Moderator
    ^ @ 1st post.
    My wire is the same, I wouldn't worry too much until it actually falls apart. There cheap to replace so I wouldn't let it concern you.
    Get a new one- there's plenty of 3rd party usb-ipod cables out there
  13. iPhoneMonster
    iPhoneMonster New Member
    Mines ripped from both ends now.. I might call apple and either buy or hopefully replace them or free because it's not cheap in Australia - $25. I don't have spares lying around because they are either from the other ipods or the other iPhone..
  14. Neo-Tech
    Neo-Tech Member
    Electrical Tape? I might try that :)
  15. psylichon
    psylichon Moderator
    Don't pull the plug out by the cable and this won't happen to you :)
    Sorry, it's the engineer in me talking...
  16. The Apple
    The Apple Zealot
    If it came with the phone it should be covered under warranty. I had my headphones replaced a couple times under warranty.
  17. Good advice, Dave. When I was in the Air Force Band, I did a couple of stints on the audio crew. Believe me, those guys were picky as hell about the way their cords and cables were treated. If you even looked at them wrong (the cables), you might have gotten a lecture.
    However, it kept our equipment in far better shape for far longer.
    I still don't understand why one of my commanders always referred to red duct tape as "rock & roll duct tape," though. :)
  18. tippingpt
    tippingpt New Member
    Same thing happened to me. I bought a new one on Amazon for 1 cent. no joke, and the shipping was $3.00. but mine was a year old already.
  19. Bitewound
    Bitewound Evangelist
    Same thing happened to mine at the other end -I took it in to the Apple store and it was replaced no questions asked.
  20. Neo-Tech
    Neo-Tech Member
    ^Really? Too bad the nearest Apple Store for me is miles away :(
    Mind you, if I order online, it might be cheaper as petrol is damn right expensive, blame "Golden" Brown.
  21. psylichon
    psylichon Moderator
Share This Page
