iPhone defenses well fortified (jailbreak issue)
DeathBySnuggles
Jul 5, 2007
88
Tampa, Fl
I've followed the posted instructions for running jailbreak and I cannot get past the "Sending more files... Rebooting iPhone..." stage and the phone stays showing the "Please connect to iTunes" message. I've tried it many times, and left it alone for a long time. Eventually the phone just resets itself and jailbreak displays a message saying "You gotta hold them longer than that" i'm assuming referring to the buttons. Anyone have this happen? Workaround?
rinual
Jul 18, 2007
49
try the alternative method of restarting, instead of holding the power and home button for 25 seconds (which should work) follow the alternative method of holding just the power button, switching it off, then holding both, or something, im not positive on the method, but i do know many of theh tutorials suggest an alternative power off at that stage.
rinual
Jul 18, 2007
49
Just gave that a shot but getting the same result. How long will it stay on the "Rebooting iPhone" message?
shouldnt take longer than 5 minutes from the point of /!\ Connect to iTunes
Make sure you don't have iTunes running but you do have jailbreak telling you to be at that point
rinual
Jul 18, 2007
49
good point mlass, if you failed to unzip the iPhone restore files into the folder, you may run into a problem. Also, once again, make sure iTunes is not running.
Corduroy
Jul 19, 2007
23
San Diego, CA
Hello - I am having the same problem. Once I do the power cycle & power button/home hold for 25sec - THe phone is at the "Connect to iTunes screen" but Jailbreak doesn't do anything. I let it sit there for 5 min.
Here is a screen shot showing what Jailbreak is doing and the files that are in my phonedmg folder.
**iTunes is not running and I went to task manager, processses I killed ipod.exe and iTuneshelper.exe
Anyone know why Jailbreak isn't copying the files?
Corduroy
Jul 19, 2007
23
San Diego, CA
I got it to work with some help from a person in the #iPhone channel.
I had to shut down Jailbreak. Do the power/home 25 sec procedure and then start jailbreak.
Joon
Jul 14, 2007
214
Could you share with us how you shut down jailbreak. I am having the same issue everyone else is having and I would like to know how to fix it as you have. Thanks.
Corduroy
Jul 19, 2007
23
San Diego, CA
The steps I was told to take were:
1) Hit the power + home buttons for 25sec
2) Once the yellow triangle with Connect to iTunes comes up start up jailbreak
at that point the files started transferring.
now the one thing I am having trouble remembering is if jailbreak asked me to do the power + home button procedure again.
The difference between what I did and all of the tutorials is that I started Jailbreak after the phone was in restore mode.
Joon
Jul 14, 2007
214
I cannot get it to go. I get to the "Connect to iTunes" screen and then the spin goes about a quarter way around, and then goes to the Apple boot up screen. Then after the phone starts up I get "You're going to have to learn to hold it longer then that, buddy!" No clue why this is doing this.
Corduroy
Jul 19, 2007
23
San Diego, CA
Have you killed the ipodservice.exe and iTuneshelper.exe processes?
Kill those, close out jail break.
DO the power button / home button 25 sec procedure
When the "Connect to iTunes" screen comes up, release
Double click on jailbreak (let it sit for a minute or 2)
If it prompts you to do the power button / home button 25 sec procedure, do it.
