iPhone displaying battery and lightning signal but not charging?
Aug 13, 2009
I have tried 3 different wall chargers, car charger and charging threw my laptop none of these work.
The phone see the charger because the battery and lightning symbol are displayed on the screen but it wont charge nor will it turn on. I have tryed rebooting my laptop with it plugged in, holding the on and home button to reboot the phone and nothing what else could it be? :(
thanks in advance for any help
iphonewarrior
13,847
701
Have you left it, with the phone switched off overnight plugged into a wall charger?
You may have a bad battery. If your jailbroken things become a little difficult as you wont be able to take it to an Apple store.
Aug 13, 2009
thats the thing I went to the Apple store yesterday and he managed to turn it on and it charged a little I don't no how he managed it so if I can get it on again ill try and upgrade it before the battery dies again then it should wipe the jail break shouldnt it?
iphonewarrior
13,847
701
You will need to do a full restore. Once it's restored, make sure you set up as new phone
Aug 13, 2009
how do I do this? will this need a lot of battery?
iphonewarrior
13,847
701
Plug your iPhone into iTunes.
You'll see a your phone's info pop up- if not just look to the left and you'll see your iPhone there. Click on it.
You will see 'Restore' - click that.
Job done.
Nikhil86
Feb 20, 2011
iPhone not charging and powering on
I have an iPhone 3g which is jailbreak. yestertday it suddently poweird off .when i tried to connect it to the pc via usb cable it showed me a red battery with lightning sybol below it but even after leavig it whole night it remains the same.i tried couple of thins told in the forums like rebooting my pc with the iPhone connected, holding the power and home key together to restart but it only ends up in the same image again.. i tried taking out the sim and charge .nothing worked. i connected it iTunes in dfu mode but it will upgrade it to ios 4.2 and i m not sure wat will happe next as mine is jailbreak one.Please help me in restarting my phone as its frustrating as nothing seems to work for me.
