iPhone does not vibrate during incoming calls?
Workoutninja
Jan 2, 2010
75
I recently upgraded my wife to the iPhone 5 and currently there is one issue I cannot figure out. When she receives phone calls it doesn't vibrate however email and text do. The setting is correct where it is supposed to vibrate. Any thoughts on how to fix this? Thank you.
Sent using iCafe app
5,578
Go to sounds and make sure vibrate is set to On. Then go to Ringtone > Vibration and make sure it's set to Alert and not set to None. If that doesn't work, do a hard reset. Press the home and power buttons at the same time and let go when you see the Apple logo.
