iPhone error -1 after trying to jailbreak help!
Aug 21, 2013
I tried to jailbreak my iPhone 3gs and it didn't seem to work and now its stuck in a restore loop and id don't know what to do.
28,365
5,507
What firmware version are you on?
28,365
5,507
What program did you use to try to jailbreak it? You can't use evasi0n on 6.1.3. You'll have to use redsn0w and use a semi-tethered jailbreak. The other option is to downgrade to 6.1.2 and use evasi0n, but this will only work if you manually saved your SHSH.
First restore to factory settings on 6.1.3 and then choose one of those options.
http://www.jailbreaknation.com/jailbreak-6.1.3-semi-untethered-on-iphone-4-3gs-and-ipod-touch-4g
http://www.evasionjailbreak.org/how-to-downgrade-from-ios-6-1-3-to-ios-6-1-2/
