iPhone freezes when I try to lock with Pandora playing
Dec 15, 2008
5,386
340
27
Pensacola, FL
I am unsure if this is Jailbreak related, but for some reason my iPhone 5 running iOS 6.1.2 freezes when I press my lock button when Pandora music is playing. I have to then do a hard reset.
I read a question on Yahoo answers about this, and someone posted to make sure all other applications are closed in the background. I did this, and I am still having the same problem.
28,365
5,506
Correct. You'll have to uninstall your jailbreak apps one at a time and test to find the culprit. Do you have any jailbreak music or radio apps installed? If so, I'd start there.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I have a radio app but it was installed through the App Store. I just checked "PandoraSkips," and this is not the culprit. I don't have any apps through Cydia that would cause this issue. I have tweaks and themes but none that I can think of that would cause this problem.
Update: LSMusicSeek may be the culprit. I uninstalled it in Cydia and the problem does not occur anymore.
