iPhone! HELP!
f0xy182
Jan 16, 2008
omg, how do you bypass the "slide for emergency" page on your iPhone without using independence or other programs, i have 1.1.2 and 04.02.13_g baseband, thanks in advanced
BTR
Oct 2, 2007
62
  1. On the activation screen, slide for emergency and dial: *#301# to make the phone call itself. (If the incoming call dialog quickly disappears but it keeps ringing, just dial 0 (remove *#301# first), and it will call itself)
  2. Answer the call, and tap on Hold
  3. Phone will call it self again, tap Decline. You will now be returned to the normal dialer.
  4. Tap on contacts, and tap the + icon to add a new. The only info you are going to add to this contact are two URL's. To add a URL, tap Add new URL. The first URL is prefs followed by a colon: prefs: and the second is jailbreakme.com. Tap Save.
  5. Your contact now has two "web pages" - tap on the first one (prefs:). This will take you to the settings dialog. The reason you want this, is because you need to connect to a Wi-Fi network, so tap on Wi-Fi, and get connected to a network, and make sure the icon on top of the screen is indicating that you are connected. While you are in the settings dialog, you should also set: General → Auto-Lock → Never.
  6. Now, press the home button, and again, slide for emergency dial 0, Answer the call, Hold and Decline the new call so that you get to the contacts. Tap on your contact (No Name), and this time tap on the other home page, jailbreakme.com
  7. Safari will launch and show you a webpage. Read through the text, before you Install AppSnapp
  8. Phone will return to activation screen, but don't panic, just wait.
  9. Phone should automaticly restart after almost a minute. . If it does not restart withing 2 minutes, click here.
  10. When the phone starts again, it should no longer say slide for emergency, but rather Slide to unlock It means it was successful! Activation is now bypassed, and phone prepared for software installation! (If you are going to use an AT&T SIM, you won't need to do the next step.)
