iPhone Home Button issues
Dec 23, 2007
I bought my 4 gig phone about 3 months ago, and i unlocked it (my warranty no longer is valid). My home key is acting all funny now... it will only work when i use a lot of force with my fingernail to slide across the button... or just push it really hard... What can i do to fix this? ive taken it to the Apple store, but they told me that they cant touch it. Has anyone had this problem? if so, is there a solution? Thanks
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Did you try shutting the phone down, and restarting? But if you went to Apple, I am sure they told you some tricks as well?
cdinca
Jul 4, 2007
397
does it feel like something is blocking it? Or does it feel normal, but just behave poorly?
Ace4261991
Jun 18, 2007
530
damn thatst he exact problem ive been dealin with for the past month.. it feels normal not liek somthing blocking it you just have to press really hard to get it to work. i hate it because sometiems i havet o press it a couple times to use it and i can barley ever use the double tap features because of this problem its so annoying. the only thing stopping me from getting it replaced is all my apps and crap i don't want to redo eveyrthing.
and ovbiously they wont help you out because you modded yours you have to restore it before you take to to them so they wont know that your warrantys voided.
They refused service for him because they saw the phone was unlocked. They see that, and you're kicked out.
- John
Dec 23, 2007
it feels like there is a lot of give to the button... it goes down really far when I push it. ive thought about possibly taking my phone apart to clean it. ive seen some dissasembly tutorials, but it looks too risky to attempt it. i guess im kinda stuck with it. :oops:
Morval
Oct 23, 2007
101
Buffalo,NY
just restore and then go to the Apple store. u will have to jailbreak and redo all your mods but your phone will work properly.
6,682
But being that it's unlocked, they will have a fit if anything other than AT&T is in the upper left corner. (unlocking is different from jailbreaking/hacking)
