iPhone home button not working also iPhone is not charging
rokas
Aug 9, 2011
hello,
I'm using iPhone 3gs and today i woke up and i realized that my iPhone home button is not working. later i plugged my phone to pc, but iPhone showed no reaction to this. any advises?
altjx
Oct 21, 2009
411
www.altonjsupport.net
It could possibly be your charger. Have you tried plugging it into another machine using the same cable and everything? Also, try plugging it into another port in the computer.
fchef25
Aug 26, 2011
this just happened to my wifes phone. whe took it to the Apple store, and it turns out that there is a wire that sometimes comes loose under the home button. it will have to be opened up and moved. then it will work. the wire is just getting in the way of the button making contact with the internal sensor.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
The same thing happened to me and I took it to Apple and it worked, I ended up getting a replacement because I had to go in for a second time because their fix didn't hold so They gave me another phone after I went back.
