iPhone + iCombi + Motorola S9 = Battery Drains!
Sep 26, 2007
I've searched the forums and it seems everyone else but me is enjoying good battery life with the combination above. However, from my experience, my battery drains after using it for just four hours. Doesn't last through the entire work day! At the end of the day I can't call anyone because my battery is dead.
Anyone have similar experiences, or know what I'm doing wrong?
Thanks.
Travelare
Sep 27, 2007
I've gotten an icombi but i can't get it to work with the iPhone
Thanks.
How did you get your icombi to work?
Sep 26, 2007
I just plugged it in. It asked to turn on Airplane Mode. I did so. Then it worked, and I turned off Airplane mode. There's no need to enable the icombi under the bluetooth devices. It will work fine without being enabled. The only device I have under my bluetooth device list is my Jawbone.
